APU of a different breed - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: APU of a different breed (/showthread.php?tid=1833) |
APU of a different breed - Jon Mastin - 06-13-2017 I did it. It works. It was well worth the time. [attachment=2841] The mount uses the factory cab shock points and is nice and secure [attachment=2842] I just have a simple mount for a generator for now. [attachment=2843] And while I was at it i removed the heavy exhaust and turned it into a weed burner style. [attachment=2844] RE: APU of a different breed - uncleal13 - 06-13-2017 No photos came through. RE: APU of a different breed - Jon Mastin - 06-14-2017 I'll try again.[attachment=2840] RE: APU of a different breed - Mr Hagg - 06-15-2017 We have a good customer that has this unit but with a honda genset. He said it works great and has had it for 2 years now.. RE: APU of a different breed - Jon Mastin - 06-15-2017 I've only seen the one Snailexpress posted. It works awesome. RE: APU of a different breed - Mrkentee - 06-16-2017 A guy had a generator on his truck. Real nice set-up. But the fuel tank on the generator was removed. He had a split fuel tank for the truck. The side which would have had hydraulic oil had gas, and a 1 psi pump to supply the generator. Reason being, he said gravity fed gasoline systems were illegal on a truck. Do you know anything about that? RE: APU of a different breed - snailexpress - 06-16-2017 (06-16-2017 )Mrkentee Wrote: A guy had a generator on his truck. Real nice set-up. But the fuel tank on the generator was removed. He had a split fuel tank for the truck. The side which would have had hydraulic oil had gas, and a 1 psi pump to supply the generator. Reason being, he said gravity fed gasoline systems were illegal on a truck.It's OK to use generator fuel tank. But something like [attachment=2850] is no-no RE: APU of a different breed - Nilao - 06-16-2017 393.65 subsection d states (d)Gravity or syphon feed prohibited. A fuel system must not supply fuel by gravity or syphon feed directly to the carburetor or injector. |
