| Front gear cover gaskit - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Front gear cover gaskit (/showthread.php?tid=1844) |
| Front gear cover gaskit - jesseisx15 - 06-17-2017 i have isx 15 2250 my front gear cover gasket starts to leak ... is there any procedure how to change it. any video reference ? RE: Front gear cover gaskit - Rawze - 06-17-2017 Start by finding out why it started leaking? -- Recently serviced? -- or excess crank case pressure?- When is the last time you replaced the crank case filter? - Those things can cause a lot of damage to the turbocharger and/or cause gaskets and seals for the engine to leak and fail in various places when not changed regularly. RE: Front gear cover gaskit - 5022 - 06-18-2017 I thought mine was starting to leak but it was the rubber plug . Put a new one in and it dried up. By the time the fan moved it around it looked a lot bigger than it was. I know that's too simple minded but it was a lot better than I had aright to expect. RE: Front gear cover gaskit - jesseisx15 - 06-19-2017 (06-17-2017 )Rawze Wrote: Start by finding out why it started leaking? -- Recently serviced? -- or excess crank case pressure?- Crank case filter was changed 4 months ago .... i checked pressure it was 0.1kpa ......I do oil service regurarly 14 to 15k mikes ... one thing I notice it leaks more when cold start engine as engine gets warmed up it gets less .... RE: Front gear cover gaskit - jesseisx15 - 06-19-2017 (06-18-2017 )5022 Wrote: I thought mine was starting to leak but it was the rubber plug . Put a new one in and it dried up. By the time the fan moved it around it looked a lot bigger than it was. I know that's too simple minded but it was a lot better than I had aright to expect.Where is that plug located RE: Front gear cover gaskit - Rawze - 06-19-2017 (06-19-2017 )jesseisx15 Wrote: Crank case filter was changed 4 months ago .... i checked pressure it was 0.1kpa ......I do oil service regurarly 14 to 15k mikes ... one thing I notice it leaks more when cold start engine as engine gets warmed up it gets less .... That reply throws up some red flags for me. 0.1kpa < -- What is it at full engine load? How old is engine? How much blow-by does it have? 4 months ago?-- tells me nothing of the mileage or how saturated that filter might be. You are aware that a lot of guys do away with that filter as their engines get older for just the reasons you are having issue with. Here is one reference... http://rawze.com/forums/showthread.php?tid=65&pid=376#pid376 |
