09 mack mp8 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: 09 mack mp8 (/showthread.php?tid=1846) |
09 mack mp8 - Shandro - 06-17-2017 Truck has just over 125000 miles doesn't get used all that much because we farm and it's used mostly in winter to haul grain to the elevator. The other day the intake manifold pressure sensor failed and was reading 40 pounds of boost. Ran the truck like that for 40 miles or so before it was derated and had to shut it off. Towed it home the rest of the way. Replaced the sensor and everything seemed great it regened and off I was hauling grain again. Two trips later code comes up for egr valve that it's either an open circuit or stuck wide open. Wires looked all good. What else could need cleaning/looking at besides the valve? RE: 09 mack mp8 - Rawze - 06-17-2017 Maybe an EGR tune-up where you pull everything apart and clean it out? RE: 09 mack mp8 - Shandro - 06-17-2017 Ya that's what I was afraid of. How difficult is it to pull off the egr cooler I imagine it would be plugged too |
