| insite - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: insite (/showthread.php?tid=1860) |
insite - flonly - 06-25-2017 Im looking at refurbished lap tops for just to use with insite only.Will windows 7 pro work or does it need to be straight windows 7 and how much ram and gigs. I might want to aso download some rawze instructional videos on it for refrence so if i need to do something i have the video with me at time of repair.thanks RE: insite - Rawze - 06-25-2017 I have seen guys run insite on .. xp win7 win8 win10 (troublesome though). RE: insite - scottydogtruck - 06-25-2017 Depends on which version of Insite you want to run.....7.6.2 works on most laptops running running at least WinXP......If you want to run the most updated version which is 8.2.2.....you have to run at least Win7 Home. RE: insite - flonly - 06-25-2017 Thanks I have seen some refurbished laptops with windows 7 pro and not sure if it was ok. |
