| 14 600 isx - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: 14 600 isx (/showthread.php?tid=1893) |
14 600 isx - Boss - 07-08-2017 filter on frame is half full air bubbles from return line in tank. engine surges or vibrates intermitantly and I hear a small popping noise in air cleaners RE: 14 600 isx - Squish099 - 07-08-2017 I assume 14 is the truck year? Sounds like you are getting air in the fuel system.. Cracked pickup? Loose fitting? Loose filter? Cracked fuel line? RE: 14 600 isx - hhow55 - 07-09-2017 I'm thinking it could be a bad return fuel block valve, because of the surging. |
