isx smoking when regen - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: isx smoking when regen (/showthread.php?tid=1898) |
isx smoking when regen - Speedy107 - 07-11-2017 Hi everybody i have ISX 871 and is smoking when regen either running or park maybe can be the dozer injector, no missing water, oil the low coolant level coming out a lot water level good. Appreciate any help can get to fix the problem. RE: isx smoking when regen - hhow55 - 07-11-2017 (07-11-2017 )Speedy107 Wrote: Hi everybody i have ISX 871 and is smoking when regen either running or park maybe can be the dozer injector, no missing water, oil the low coolant level coming out a lot water level good. Appreciate any help can get to fix the problem. I'm confused, can you reword your post. RE: isx smoking when regen - Speedy107 - 07-12-2017 ISX 871 SMOKING WHEN REGEN EITHER RUNNING AND PARK, I'M THINKING IS THE DOZER INJECTOR, NO MISSING ANY WATER OR OIL, WATER LEVEL WARNING COMING OFF AND ON A LOT. IT WAS YESTERDAY TODAY IS DOING GOOD, THE 2637 FAULT DOC COMING ACTIVE A LOT 1 DAY IS ACTIVE THE NEXT DAY ALL RIGHT. RE: isx smoking when regen - Rawze - 07-12-2017 First thing might be to test the coolant system with a pressure test set to ensure it is not building pressure because of a head gasket or other issue. Smoke during a regen, depending on what it is doing may or may not be normal. it depends on the circumstances and other factors. Could also be coolant intrusion as you have stated you are having coolant level issues. Being a bit more specific may help like what kind of truck, what kind of smoke and how bad it becomes, when it started to do this, regen history, age/miles, etc. and any other related info would likely allow others to provide some better answers. |
