Ultracapacitors, Are they worth it?,... - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Rawze's Technical Documents (/forumdisplay.php?fid=38) +--- Thread: Ultracapacitors, Are they worth it?,... (/showthread.php?tid=193) |
RE: Ultracapacitors, Are they worth it?,... - Duber - 05-16-2020 I haven't been on the forum for long, but reading about the AGM battery upgrade, and Ultra capacitors make good business sense. I started using the newer technology of AGM over 7 years ago. Communication equipment in the oilfield at the remote well locations is how I was introduced to them. Since then I have replaced all my mobile units wet lead acid batteries with AGM. figure at the 3 year point the batteries have made me money now. Have never missed a start, even after a long night of lights on by accident. Or brutal cold of 7 or 8 days at minus 40c sitting in camp remote locations of Northern Alberta. Capacitors are the next change, as now I am starting to see them in use for the industrial systems of (power van)potable genset units . The use and application of newer technology needs to be discussed and shared more. Thanks you Rawze for this forum. RE: Ultracapacitors, Are they worth it?,... - 5022 - 05-17-2020 I have had Maxwell ESM in my last two trucks . It has been a real game changer for me. I had agm in the first and regular batteries in the present truck. I my opinion the maxwell is a bigger plus for the way I run than the agm. I spend every other night in truck but only for ten hour break and turn for home on relay. Regular batteries run espar and coolant heater just fine so far. I screwed up once on new truck changing fuel filter but even then in ten minutes it cranked and started. I only made that mistake once. It is always nice to know you always have a start in the maxwell no matter if the batteries get pulled down or not. |
