Engine problem - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Engine problem (/showthread.php?tid=1943) |
Engine problem - stumpjumper - 07-23-2017 Engine losing power throwing codes 4334 and derating any ideas cummins replace the Def pump went 150 miles did it again. RE: Engine problem - marek4792 - 07-23-2017 Is your harness in good shape? I noticed when something goes wrong with the DEF system most of the time it is electrical, but having a repeated pump failure sounds like there could be a blockage burning up the pump. Rawze posted pictures of one truck he looked at with similar complaints (and the truck owner having spent a large amount of money with no luck) that had the DEF crystallize almost blocking the pipe where the DEF injector was. RE: Engine problem - Rawze - 07-24-2017 (07-23-2017 )marek4792 Wrote: Is your harness in good shape? I noticed when something goes wrong with the DEF system most of the time it is electrical, but having a repeated pump failure sounds like there could be a blockage burning up the pump. Rawze posted pictures of one truck he looked at with similar complaints (and the truck owner having spent a large amount of money with no luck) that had the DEF crystallize almost blocking the pipe where the DEF injector was. that was this post... http://rawze.com/forums/showthread.php?tid=283&pid=1807#pid1807 |
