cleaning headlights - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Things that may help others... (/forumdisplay.php?fid=46) +--- Thread: cleaning headlights (/showthread.php?tid=199) |
cleaning headlights - hhow55 - 03-16-2016 https://m.youtube.com/watch?v=QWMJubLqnRw RE: cleaning headlights - simon999 - 03-16-2016 https://m.youtube.com/watch?v=sNMlVZyem78 Cleaning using toothpaste, very effective. RE: cleaning headlights - ashdan2010 - 03-16-2016 Wet Sand with 1200 grit then spray with clear coat and you won't have to clean them for 3 years. They will look brand new. RE: cleaning headlights - snailexpress - 03-17-2016 (03-16-2016 )ashdan2010 Wrote: Wet Sand with 1200 grit then spray with clear coat and you won't have to clean them for 3 years. They will look brand new.Some more top secrets. Don't use cheap clear coat in rattle can from auto parts store. It will yellow in short time. The good one (two parts formula) you can buy from professional auto paint supply store or amazon. After clear coat drys hard wet sanding 3000 - 4000 The finish step is hand polishing with red lipstick for exceptional luster. DON"T STEAL WIFE'S LIPSTICK deadly dangerous! RE: cleaning headlights - kryten - 03-17-2016 Not any more dangerous than the wife finding "your" lipstick in your truck. Reminds me of an old joke. "hi Bill haven't seen you in a coons age, how ya been?" "pretty good Dan, gotta say though you're the last guy I would ever have thought to wear an earring. How long have you had that?" "since my wife found it in my truck last year" Sex and the headlight's - hhow55 - 03-20-2016 https://www.youtube.com/watch?v=_pr1F8mPR0U&feature=iv&src_vid=QWMJubLqnRw&annotation_id=annotation_599075451 RE: cleaning headlights - hhow55 - 03-20-2016 https://www.youtube.com/watch?v=b8KzRFo1K8Y |
