| Idle Speed - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Idle Speed (/showthread.php?tid=20) |
Idle Speed - axe - 02-19-2016 I can not raise idle speed with cruise control. 09 Prostar CM871. Any ideals? RE: Idle Speed - Grape Ape - 02-19-2016 Could you ever do it, or is it recent? If you never could, it might just not be enabled. You can set that parameter with Insite. If it's a new issue, does the cruise work correctly? RE: Idle Speed - axe - 02-19-2016 (02-19-2016 )Grape Ape Wrote: Could you ever do it, or is it recent? If you never could, it might just not be enabled. You can set that parameter with Insite. If it's a new issue, does the cruise work correctly? It has never worked since I had it. Cruise works fine. I guess it is disabled. I meant to mention it to Rawze when he did some work on it but forgot. I will check out when I get home. Thanks RE: Idle Speed - Rawze - 02-19-2016 (02-19-2016 )axe Wrote:(02-19-2016 )Grape Ape Wrote: Could you ever do it, or is it recent? If you never could, it might just not be enabled. You can set that parameter with Insite. If it's a new issue, does the cruise work correctly? I would be happy to turn it on for you next time you get a chance to stop by this way. it is just a setting in Insite. RE: Idle Speed - axe - 02-19-2016 (02-19-2016 )Rawze Wrote:(02-19-2016 )axe Wrote:(02-19-2016 )Grape Ape Wrote: Could you ever do it, or is it recent? If you never could, it might just not be enabled. You can set that parameter with Insite. If it's a new issue, does the cruise work correctly? Thanks Rawze. See ya soon RE: Idle Speed - Crafter - 02-19-2016 (02-19-2016 )Rawze Wrote:(02-19-2016 )axe Wrote:(02-19-2016 )Grape Ape Wrote: Could you ever do it, or is it recent? If you never could, it might just not be enabled. You can set that parameter with Insite. If it's a new issue, does the cruise work correctly? which setting? one of my trucks does it with cruse and the other doesn't. do you remember which one it was? RE: Idle Speed - Cuya - 02-19-2016 (02-19-2016 )Crafter Wrote: which setting? one of my trucks does it with cruse and the other doesn't. Here is what mine looks like [attachment=1115] and here, though i think this is different for different model trucks. [attachment=1116] |
