Ecm password question - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Ecm password question (/showthread.php?tid=2027) |
Ecm password question - Fergie - 08-15-2017 I got a bill from dealership for $200 for zap it to clear password. I went and talked to them today cause the fleet reset the password to 0000. So I was upset I got charged this. The mechanic retired last week so they looked through his notes. Supposedly the 0000 got him into the computer but the cruise control limit had another password that wasn't cleared. Are they covering their a$$ on this? Or can there be multiple passwords inside the ecm? RE: Ecm password question - Rawze - 08-15-2017 (08-15-2017 )Fergie Wrote: I got a bill from dealership for $200 for zap it to clear password. I went and talked to them today cause the fleet reset the password to 0000. So I was upset I got charged this. The mechanic retired last week so they looked through his notes. Supposedly the 0000 got him into the computer but the cruise control limit had another password that wasn't cleared. Are they covering their a$$ on this? Or can there be multiple passwords inside the ecm? The ecm has 2 passwords. The user password, and the OEM password. RE: Ecm password question - Cuya - 08-15-2017 Hundred bucks more from china & you own inline adapter and everything needed instead of getting hosed. RE: Ecm password question - Fergie - 08-15-2017 (08-15-2017 )Cuya Wrote: Hundred bucks more from china & you own inline adapter and everything needed instead of getting hosed.I now have it and the ecm has been taken care of by Unilever's shop the other day. |
