Cleaning the air side of your radiator - Printable Version
+--- Thread: Cleaning the air side of your radiator (/showthread.php?tid=2045)
Cleaning the air side of your radiator - kryten - 08-20-2017
Came across this that may be of some use to others. This guy is using it for a tractor but I see no reason why it couldn't work on a truck.
Here is the website.
http://www.radiatorgenie.com/category_s/46.htm
$39.95 USD or about $437 CAD :D.
RE: Cleaning the air side of your radiator - Hammerhead - 08-20-2017
(08-20-2017 )kryten Wrote:  $39.95 USD or about $437 CAD :D.
You for got plus customs fees and GST, don't forget cousin Justin's share...
RE: Cleaning the air side of your radiator - kryten - 08-20-2017
Oops, forgot the government theft. That should bring the total cost up to just under $600 CAD. Speaking of our second favourite wannabe commie I'm off to make another Justin Trudoh', I hope there's enough paper to finish the job.
RE: Cleaning the air side of your radiator - ZeroNthedark - 08-20-2017
Nice catch on this one! One of my customers has a literal fire hose that I've used in the past, to middling success. This looks to make it a bit easier to push debris back out the front instead of wrangling a 2" hose around both sides of the truck.
