| Cm2250 code 1925?? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Cm2250 code 1925?? (/showthread.php?tid=2137) |
Cm2250 code 1925?? - jimeneztrans84 - 09-17-2017 Got this code 1925 Aftertreatment Fuel Shutoff Valve 1. Does this mean doser injector is bad or fuel shut off valve sensor went bad? I cleaned doser injector about 50k miles ago so maybe it's time for new one? RE: Cm2250 code 1925?? - RollinCoal - 09-17-2017 No sir, There is a little module on the left rear of the engine, If you back trace the fuel line from the fuel doser it will lead you right to it and its a pain to get to, But there are what looks like 2 sensors that screw in from the bottom the one closest to the front is the fuel shut off valve Depending on the truck, its almost easiest to pull the starter to get to it RE: Cm2250 code 1925?? - jimeneztrans84 - 09-17-2017 I just swapped it out $80 for shut off valve. I did forced regen and still throws code 1925. Unilevers says maybe 7th injector or wiring fault. I will try to inspect doser injector tmrw when engine is cold. RE: Cm2250 code 1925?? - RollinCoal - 09-17-2017 I just ran into this on a truck thursday my self It was throwing the 1925 code and the pressure sensor was bad Looking at the pressure threw insite with fuel and air pressure bled off it was still showing 86 psi If you have insite check the pressure |
