| 2004 ISM - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: 2004 ISM (/showthread.php?tid=2146) |
2004 ISM - pbplus9 - 09-20-2017 I'm new here, so not sure if this will get me anywhere. My brother in law has a 2004 International farm truck with a Cummins ISM engine he's been having some trouble with. It has had a turbo lag since he got it, and just had a mechanic block the EGR, but the mechanic claimed he couldn't reprogram the ECM because it had 2 ECMs, that wouldn't let him modify the programming. My brother inlaw knew I had just started on this forum and wanted me to check with you guys to see what your thoughts were on how he should proceed. The truck had a rebuilt engine installed just before he got it and it has a little less than 300k miles now. (Engine replaced at 200k). Is there a way to get some private help on the EGR issues also. Thanks. RE: 2004 ISM - Rawze - 09-20-2017 That would be Unilevers and/or Gearhead. RE: 2004 ISM - Unilevers - 09-20-2017 they can be done, its just a pain. thats a 570/870 dual ecm beast. |
