| Accessorize your shade tree - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Things that may help others... (/forumdisplay.php?fid=46) +--- Thread: Accessorize your shade tree (/showthread.php?tid=225) |
Accessorize your shade tree - 1096 - 03-19-2016 I built this shelter last summer to stay out of the sun while streching my truck from a 2 axle into a 4 axle. It didn't take long to put up and lasted for the whole project and beyond. The tarps are suspended from a 100' 1/8" cable purchased from Harbor Freight (less than $10). The 2 tarps are 9x18 and suspended form cable via chain links. I rigged small ropes along side the cable tied to the top ends of the tarp so that I could slide the whole thing up and down the cable. I collapse the tarps and reef them to the tree when not in use. I used cheap carabiner clips at the 4 corners to secure the ropes (quick disconnect for wind). I'm trying to think of a name for this (it takes time). Got any ideas? Just imagine the sun shining up instead of down. I can't figure out how to fix this. RE: Accessorize your shade tree - yamajason - 03-19-2016 Nice. To "Rotate" the image on Android I like this Free app https://play.google.com/store/apps/details?id=com.iudesk.android.photo.editor For Linux and Windows I like this Free program GIMP https://www.gimp.org/downloads/ RE: Accessorize your shade tree - yamajason - 03-19-2016 This is a subject I think most of us O/O have thought about. Especially in the cold winter time, the dusty windy days, when it is not in the budget to get a 60 foot steel building... |
