Cm570 hesatation underload - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cm570 hesatation underload (/showthread.php?tid=2358) |
RE: Cm570 hesatation underload - Red - 11-07-2017 Will do thanks RE: Cm570 hesatation underload - ntadiesel - 11-07-2017 Check the wiring to the intake manifold combo sensor. Might not apply to your long bonnet truck but I've seen a few 4800 that had the engine fitted in the Western Star factory in Australia where the wiring was touching the cab and when you'd hit a bumb in the road they would loose connection but it happened to quickly for the ecm to register any faults. RE: Cm570 hesatation underload - Red - 11-07-2017 Thanks will check RE: Cm570 hesatation underload - Tanker93 - 12-03-2017 Any luck? |
