MISC / A*P*units / Tricks - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Things that may help others... (/forumdisplay.php?fid=46) +--- Thread: MISC / A*P*units / Tricks (/showthread.php?tid=236) |
MISC / A*P*units / Tricks - Sergiu - 03-23-2016 Here is a easy trick for installing a 1"id double shielded bearing https://www.youtube.com/watch?v=LVODJm05plw RE: MISC / A*P*units / Tricks - NewSon - 08-19-2016 hahaaaa. thats a nice one!!! RE: MISC / A*P*units / Tricks - Runt - 08-20-2016 Cool! RE: MISC / A*P*units / Tricks - Sergiu - 09-06-2016 Here is a thing yesterday happened with my carrier APU Starter works fine, air filter clean, fuel solenoid ok, but after starter had stopped spinning engine won't start. Spent a day searching for other reasons, while suddenly observed that one stator's wire was broken inside the alternator :idea: (please see the image below) Disassembled the alternator, and saw that 4 of 5 wires were broken. After fixing it engine has started as usually |
