| CM2250 front main seal, any info appreciated! - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: CM2250 front main seal, any info appreciated! (/showthread.php?tid=2375) |
CM2250 front main seal, any info appreciated! - JMBT - 11-12-2017 Does anything besides the Cummins tool work for replacing the front main crank seal??? RE: CM2250 front main seal, any info appreciated! - Hammerhead - 11-12-2017 (11-12-2017 )JMBT Wrote: Does anything besides the Cummins tool work for replacing the front main crank seal??? I bought a complete set of tools from the seller in the below link; Front crank seal removal/install tool Rear crank seal removal/install tool Cam gear puller Cam timing wedge & crank pin set He is a machinist and the quality of the tools he makes is fantastic. I contacted him via the email in the photos and we made a deal for all of the tools direct, no eBaY fees. https://www.ebay.com/itm/Cummins-Isx-15-4918991-Crankshaft-Front-Seal-Remover-Installer/253246359031?epid=1760606272&hash=item3af6a8c5f7:g:qxwAAOSwv9hW2lk6&vxp=mtr RE: CM2250 front main seal, any info appreciated! - JMBT - 11-12-2017 Thanks hammer! Too funny, that link goes directly to the same guy I just ordered from! RE: CM2250 front main seal, any info appreciated! - JMBT - 11-12-2017 Hammer what kind of grease did you lube the seal with when you installed it? RE: CM2250 front main seal, any info appreciated! - Hammerhead - 11-13-2017 (11-12-2017 )JMBT Wrote: Hammer what kind of grease did you lube the seal with when you installed it? I'm sure you'll be impressed with his quality, I am. My favorite assembly lube...Vaseline! Believe it or not, that all I've ever used when I've put my dragster motors together. It's sticky to hold pieces in place while assembling, it's slippery and lubrictes sufficiently until the oil system is fully primed, and best of all, it evaporates with heat leaving no traces behind. What could be better? RE: CM2250 front main seal, any info appreciated! - JMBT - 11-13-2017 Thanks again Hammer! Vaseline it is, I have some sitting around for lubing under my nose when we are shooting paint! It does a good job trapping the paint before it makes it in! RE: CM2250 front main seal, any info appreciated! - JMBT - 11-21-2017 [attachment=3288][attachment=3287]Hey Hammer, the tool worked great! Thanks again for the feedback. |
