| Cm2250 egr valve removal - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Cm2250 egr valve removal (/showthread.php?tid=2381) |
Cm2250 egr valve removal - Beaver - 11-13-2017 I tried to remove the egr valve today and couldn't seem to get it loose. Just curious if I'm overlooking something. 2 bolts and the 2 hose clamps and thats it basically right?? RE: Cm2250 egr valve removal - Ironhead - 11-13-2017 3 bolts one middle looks like it's behind the wires RE: Cm2250 egr valve removal - Rawze - 11-13-2017 here is how I did one with a friend... RE: Cm2250 egr valve removal - Beaver - 11-14-2017 (11-13-2017 )Rawze Wrote: here is how I did one with a friend...Isnt this on a 871 though? Different set up right? Sorry for the ignorance but when i started watching, it seemed like the 2250 was going to be different so I stopped watching. I will go back and watchit all the way through. Thanks for the help gentlemen! RE: Cm2250 egr valve removal - Signature620 - 11-14-2017 That video is specific to cm871. On a cm2250 the valve is above the exhaust manifold. All you need to do is disconnect the piping at both ends then unplug it and remove the 3 bolts.[attachment=3279] RE: Cm2250 egr valve removal - Beaver - 11-14-2017 OUTSTANDING! THANKS! Ok now for 2 more questions haha. 1-where did you get that schematic? 2- how do I post pics in my posts like that? RE: Cm2250 egr valve removal - Rawze - 11-14-2017 (11-14-2017 )Beaver Wrote: Isnt this on a 871 though? Different set up right? Sorry for the ignorance but when i started watching, it seemed like the 2250 was going to be different so I stopped watching. I will go back and watchit all the way through. Thanks for the help gentlemen! yup,.. you have a deferent engine. I have never had one off that model motor. RE: Cm2250 egr valve removal - Rawze - 11-14-2017 (11-14-2017 )Beaver Wrote: OUTSTANDING! THANKS! Ok now for 2 more questions haha. 1-where did you get that schematic? 2- how do I post pics in my posts like that? register your engine on quickserv.com -- its free for up to 5 serial numbers and you will have access to everything you want to know about your engine. RE: Cm2250 egr valve removal - Signature620 - 11-14-2017 And when you are writing a post or a reply, down the bottom you'll see "choose file". Select a photo you want to attach then press "add attachment". Then once it uploads, press "add to post" or "insert to post" (something along those lines). |
