Pete 386 clutch switch - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: Pete 386 clutch switch (/showthread.php?tid=244) |
Pete 386 clutch switch - ucl55 - 03-24-2016 Does anybody know the location of clutch switch on 08 pete 386, I need to change it or may be if there is adjustmet. It only works intermit and bcouz of this I can't do parked regen also my cruise and jake brakes stops working. RE: Pete 386 clutch switch - kryten - 03-24-2016 I can't be sure of the 386 but my old '96 377 the clutch switch was actually under the cab somewhere on the linkage, outside in all the weather. RE: Pete 386 clutch switch - 389driver - 03-24-2016 It is underneath the cab where the clutch pedal pivots. You've really got to look to see it. Get ready for sticker shock when you go get a new one! RE: Pete 386 clutch switch - Mrkentee - 03-24-2016 Replaced mine last year and it's acting up again. RE: Pete 386 clutch switch - ucl55 - 03-24-2016 Thanks guys RE: Pete 386 clutch switch - jorden486 - 03-29-2016 Be sure to check the spring. If it broke the pedal could be falling slightly enough to cause it to switch. Hook a bungee strap to the pedal and drive down the road and see if cruise works. |
