| engine brake stuck on? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: engine brake stuck on? (/showthread.php?tid=2491) |
engine brake stuck on? - sbtrucking - 12-13-2017 Hello fellas, I have a problem with my cm2250 it ran great for past couple hundred miles with mm tune, I was driving the other day it developed a problem it started loosing power and slowing down fast, it was pinging and smoking a lot, I stopped and changed the filters I thought they pluged up because I shocked the tanks with biocide. I thought problem was fixed with filter change truck ran great until I decided to test the engine brake, same thing happend like I dropped an anchor lots of smoke and feels like pinging crawling at few mph, I turn the engine brake off after a minute it clears drives good again, everytime I engage the engine brake same thing, seems loke its getting stuck on. what can couse it? thanks in advance for any help RE: engine brake stuck on? - Mr Hagg - 12-13-2017 You got a jake rocker sticking. Need to pull valve cover off and activate the solenoids one at a time and see which one is sticking and replace. DONOT use jakes until fixed can and will cause major engine damage... RE: engine brake stuck on? - Rig Wrench - 12-13-2017 Had the same issue on a 2250 a couple years ago. It was a solenoid. I could see the oil screen busted out on both solenoids. 2 new ones and it never bothered again RE: engine brake stuck on? - Unilevers - 12-14-2017 Jake solenoids, its fairly common i see alot of them. Engine sounds terrible! RE: engine brake stuck on? - sbtrucking - 12-28-2017 Rockers were moving free, replaced both solenoids around $90 each took about an hour easy fix and problem fixed. Thanks fellas |
