| Isx oil pressure drops when let off throttle - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Isx oil pressure drops when let off throttle (/showthread.php?tid=2492) |
Isx oil pressure drops when let off throttle - Kevinb3373 - 12-14-2017 New member, need help. I have had 2010 prostar with cummins isx for 3 yrs. 778000 miles, have done the egg, dpf delete. Just got oil changed Monday, have run 1500 miles, on wed my red triangle and stop engine warning came on in display when I came to a stop light or getting off of highway. After I pulled over, stopped engine, waited 5 min, turn it back on, start it up and triangle is gone. While cruising highway speed of 62 at 1400rpms pressure was 38,39psi. Then dropped to below 20 when stopping. Full of oil also. Pressure sensor, relief spring? Oil pump? I've read so much info on here my head hurts!! Where should I start, filter change?, sensor? Gauge? Should I even drive it Thanks RE: Isx oil pressure drops when let off throttle - Waterloo - 12-14-2017 (12-14-2017 )Kevinb3373 Wrote: New member, need help. I have had 2010 prostar with cummins isx for 3 yrs. 778000 miles, have done the egg, dpf delete. Who did the "Tune" on the ECM and what else did they do to the motor? That is the first question that needs to be answered. And that is the CM-871, correct? RE: Isx oil pressure drops when let off throttle - Kevinb3373 - 12-14-2017 A friend of mine did the tune on ecm. Per what rawse said on his delete video. On the valve cover it just say isx 435st. RE: Isx oil pressure drops when let off throttle - Waterloo - 12-14-2017 You need someone to look at that, I wonder if he used the correct program/file. The proper file code that he should have used is on the side of the motor on the engine plate. It will read av100***. That would be the first place I check, you will need an Inline 5 or 6 reader to see that in your ECM. You may just have a Volvo or Peterbilt file in there. Ask your buddy if he is using truck specific av files or is he just using the same file for all of the trucks he has done. Until then, I would not drive it. Oil pressure dropping, you need to find out why. May be the programing, may be something else. Programing is where I would start. RE: Isx oil pressure drops when let off throttle - Kevinb3373 - 12-14-2017 The delete was done in Aug 2016. It has never done this before, always good pressure for 15k miles. Now I just got done with my day, and had no issues, pressure good while running, and it slowly dropped to 20 when coming to a stop. RE: Isx oil pressure drops when let off throttle - Rawze - 12-15-2017 (12-14-2017 )Kevinb3373 Wrote: A friend of mine did the tune on ecm. Per what rawse said on his delete video. I don't recall ever making a delete video. In fact, I would never make a delete video. ===== next,.... 18-20 psi at idle is normal for an ISX with 34-38 above 1000 rpm depending on oil temps. cummins spec is anything above 15 psi at idle. If your oil pressure has fallen off then change the oil a second time and the filters. It very well may be all the carbon and crap from 700+k miles loosening up and clogging the filter. If that does not help, then its time to pull the rod and main bearings and replace them anyways at that age. Just some suggestions there. ======= Making such drastic changes to an old engine with 700+k miles on it is very very risky.It is like asking grandma to suddenly run faster on the tread-mill and start breathing pure oxygen when she is already tired and worn down. The oxygen may help but will do likely her in much quicker. Some people get away with it but some just don't when they are old and you do that stuff. 700+k with EGR is like 1.2 mil without and all the carbon packing, soot-clogged cross channels, soot-packed components, soot-packed pistons, etc. can hide a lot of underlying problems. Doing such things to older equipment should be done by someone who can compensate for its age so that any kind of drastic changes like that are kind to the engine. Things like NOT turning up the power, replacing old sensors, re-adjusting the valve train, replacing rod/main bearings, testing the fuel system and injectors, + going through the engine to ensure there will be no problems from other worn out components. ===== - I would suggest you have BOTH the engine AND the programming looked at professionally. Any kind of instructions your friend may have used is likely A. - out of date, and B. - Though it somewhat works for some trucks, any instructions that someone has used that I have ever seen was meant for people just trying to learn tuning and is no kind of final solution. Getting it to Unilevers, Mr. Hag, or Gearhead to get it dialed in correctly for your specific model and make of truck would be the proper thing to do. Then also having the engine and truck inspected etc. to ensure there aren't any underlying problems about to cause a failure. Those ISX engines only last so long and some do, but very few actually make it much past 800 or 900k miles from what most people are reporting. RE: Isx oil pressure drops when let off throttle - Kevinb3373 - 12-15-2017 Sorry Rawse if I mis spoke about the video. |
