Fuel pressure at idle?? - Printable Version
+--- Thread: Fuel pressure at idle?? (/showthread.php?tid=2498)
Pages: 1 2
RE: Fuel pressure at idle?? - Unilevers - 12-17-2017
thats way outa spec, you will need to fix that. they fluctuate maybe 250 psi, even 1450 i would be fixing that.
RE: Fuel pressure at idle?? - Rawze - 12-17-2017
Maybe stop by mr. hags and see what is going on with it when you get some time.
RE: Fuel pressure at idle?? - JMBT - 12-18-2017
Thanks for the ideas. I’ll keep you guys posted. I am loaded now, 92,500 gross and she is pulling beautifully, hopefully not the “calm before the storm”. When I get load kicked off on Tues, I will do some investigating.
