Regen light on - Printable Version
+--- Thread: Regen light on (/showthread.php?tid=2509)
Pages: 1 2 3 4 5
RE: Regen light on - Rawze - 01-05-2018
(01-04-2018 )hhow55 Wrote:  Ok,
Went 950 miles since reset on ecm and can and the DPF light is screaming again...
Did a forced regen, and sure getting tired of this. Also have fault code 2777, which points to a problem involving the inhibit switch. The inhibit switch will not allow me to do a forced regen, so I have utilize Insite to complete the task. Insite says something about ecm programming for the inhibit switch, yet I had ecm flashed to the correct av10046. I'm thinking maybe I have a bad inhibit switch on the dash, since I can not do a forced regen when pressing the rocker switch.
Thx in advance
Someone can flash it with the right program, but that does not mean the inhibit switch setting is guaranteed to be correct. That is part of the adjustable features and parameters and if someone did not back them up and restore them properly, or has set the wrong address for it, then it can have some problems like your describing. It can also lead to the thing not performing rolling regens properly too if the switch is reporting it is in the inhibit position.
RE: Regen light on - hhow55 - 01-05-2018
Thx in advance
I'm thinking that when ecm was re flashed, it was not properly backed up and restored. Is it possible for me to go into features and parameters in insite, and make the necessary change?
RE: Regen light on - schISM - 01-05-2018
Yup, in features and parameters expand the aftertreatment then dpf then make sure your switch for inhibit and start regen is enabled. I had to do this with this last truck I bought and it had the correct programming and came configured from kenworth this way. You can also enable exhaust high temp. light and choose at what temp. and speed its allowed to come on.
(01-05-2018 )schISM Wrote:  Yup, in features and parameters expand the aftertreatment then dpf then make sure your switch for inhibit and start regen is enabled. I had to do this with this last truck I bought and it had the correct programming and came configured from kenworth this way. You can also enable exhaust high temp. light and choose at what temp. and speed its allowed to come on.
Thank you very much Mr. Schism,
I appreciate you mentioning the exhaust high temp light since mine never comes on.
What temp, and speed you recommend it to come on?
Your welcome, and I set mine on at 800, off at 700 and on under 10mph
I'm in the ecm, and the DPF is showing disabled.
I right click. Do I restore original value?
