Anyone lower front end on kw t660? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Anyone lower front end on kw t660? (/showthread.php?tid=2559) |
Anyone lower front end on kw t660? - jimeneztrans84 - 01-03-2018 Needing new steer tires here soon and wanted to lower the front of my t660. I know I can remove the block under springs but can the springs just lay on the axle or do I need a thin plate for springs to sit on? Also will need smaller u bolts and shocks. Anyone have any part numbers? RE: Anyone lower front end on kw t660? - smorgan87 - 01-03-2018 Gotta have them shims to keep the caster/camber right. Dunno what height block is under it but a good alignment shop should be able to get thinner shim blocks (and get it cruisin better than factory) |
