Trans temp wire 2010 PB 386 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: Trans temp wire 2010 PB 386 (/showthread.php?tid=257) |
Trans temp wire 2010 PB 386 - Mrkentee - 03-26-2016 I added gauges to my truck, which meant adding temp sensors to the rears and the trans along with jumper wires to the existing plugs located with the wiring along the frame rail. But, I am stumped finding the one for the trans temp. Does anyone have any idea where I should be looking? I found one for "aux trans temp" and was hoping it could be made to work but you can't. Unless I used an "aux trans" gauge. Because the computer knows the difference. (Multiplex system) ??? RE: Trans temp wire 2010 PB 386 - Mrkentee - 03-28-2016 Does anyone have a similar model Peterbilt that could tell me the general location of that plug? RE: Trans temp wire 2010 PB 386 - Rawze - 03-28-2016 Maybe someone will chime in with a picture or 2. I have never dealt with that kind of stuff myself. RE: Trans temp wire 2010 PB 386 - Unilevers - 03-28-2016 its under the cab right behind the back of the head tied in a big clump of wires. it will be labelled, found it when i had the tranny out and was looking around. RE: Trans temp wire 2010 PB 386 - Mrkentee - 03-28-2016 (03-28-2016 )Unilevers Wrote: its under the cab right behind the back of the head tied in a big clump of wires. it will be labelled, found it when i had the tranny out and was looking around. Ha! I found it. It wasn't exactly there, but it was close by. I wasn't expecting it to be there. Thanks a lot! |
