Got a ? For you Pete boys - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: Got a ? For you Pete boys (/showthread.php?tid=2592) |
Got a ? For you Pete boys - the missing link - 01-12-2018 It's colder then a ( insert here ) up here . I noticed on a lot of Petes the passenger side stack is frosted up real good with no exhaust coming though it ,only the drivers side . Does anybody know what this is from . Thanks , just curious RE: Got a ? For you Pete boys - 5022 - 01-12-2018 Maybe regen , mine carries most the extra heat on the drivers side and when it's that cold condensation is terrible on mine. RE: Got a ? For you Pete boys - Starlight - 01-12-2018 Let me guess, your truck is only a couple years old. If so then know that paccar products only exhaust out one stack. The other is just there for looks. If its a older truck then i dont know. RE: Got a ? For you Pete boys - Little_John - 01-12-2018 That is because there's only 1 stack that is connected to the exhaust system. The other one is just for the look. RE: Got a ? For you Pete boys - the missing link - 01-12-2018 O.k thanks a lot everybody for your input ... No I have a old 871 corn binder , I was just seeing this a lot .haha |
