| Cm2250 Injector O ring question - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Cm2250 Injector O ring question (/showthread.php?tid=2621) |
Cm2250 Injector O ring question - JMBT - 01-18-2018 Ok, so I ended up pulling injectors 1,2,&3 again today...don’t ask why....re-lubed them and re-torqued. I had placed new O rings on the injector and fuel connector the first time, but since I had to break the torque and pull them again, do I have to replace the Orings again?? They still looked fine and the motor hasn’t ran.. what do you guys think?? order new O rings and replace?? Or they should be fine since the motor hasn’t ran since the original replacement yesterday?? RE: Cm2250 Injector O ring question - Starlight - 01-18-2018 You will not have an issue by reusing them. Relube them well and reinstall. Dont mix the injectors and fuel connectors up as it can result in a fuel leak afterwards.. Make sure they stay together. Happy wrenching. RE: Cm2250 Injector O ring question - JMBT - 01-19-2018 Starlight, thanks so much for the reply!! I was hoping that would be the case! RE: Cm2250 Injector O ring question - Signature620 - 01-19-2018 All those o-rings do is keep return fuel and any high pressure leaks inside the return circuit. RE: Cm2250 Injector O ring question - jimeneztrans84 - 01-19-2018 Is replacing injectors on cm2250 really hard to Do? Any tips? Is it the same as a 871? I would like to learn how to change my own injectors and keep running to mechanic for everything. Doing my own over head soon, seen rawze's video doesn't seem hard... RE: Cm2250 Injector O ring question - Wiseman - 01-19-2018 2250/2350 and 870/871 are different. Open quickserve and read . It’s free . RE: Cm2250 Injector O ring question - JMBT - 01-19-2018 Jimeneztrans84: it is not difficult. Probably easier then the 871, just different. Simon999 on the forum posted me a link to a YouTube video he made when he was doing a valve guide seal replacement on his 2350, (same procedure as our 2250’s). Private msg him and ask for the link it will show you what you are in for. |
