Def Tank Temperature - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Def Tank Temperature (/showthread.php?tid=2670) |
Def Tank Temperature - nirubini - 01-26-2018 CM 2250 In the Regin Report def fuel tank temperature most of the time display 43F-46F. I just want to know why temperature not changing to more or down. If anyone knows about this can you please advise me. I think temperature sensor okay. Thank you. RE: Def Tank Temperature - snailexpress - 01-26-2018 (01-26-2018 )nirubini Wrote: CM 2250DEF temperature controlled by computer. It will open heating system valve and heat or thaw if DEF is frozen. If you have Insite check DEF temperature in morning time should be as outside temp. |
