Sinewave inverter anyone have recommendatioms? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Other truck related Help... (/forumdisplay.php?fid=71) +--- Thread: Sinewave inverter anyone have recommendatioms? (/showthread.php?tid=2695) Pages: 1 2 |
Sinewave inverter anyone have recommendatioms? - Blake - 01-30-2018 I use a CPAP machine so I need to purchase a good pure sinewave inverter. Anyone have a model that they recommend? RE: Sinewave inverter anyone have recommendatioms? - Rawze - 01-30-2018 Considering it is for a medical device, the top of the line of all brands is Xantrex Pure sine wave inverters. RE: Sinewave inverter anyone have recommendatioms? - Blake - 01-30-2018 Thanks Rawze! RE: Sinewave inverter anyone have recommendatioms? - mmssvv - 01-31-2018 I don't think mine Xantrex is pure sine but definitely is the best brand I ever own.It is originally installed in my Volvo and I am running a lot of stuff on it.Highly recommending this brand. RE: Sinewave inverter anyone have recommendatioms? - Blake - 01-31-2018 Thanks MM. RE: Sinewave inverter anyone have recommendatioms? - Blake - 02-07-2018 Fridge, 900 watt small micro, laptop and cpap what size? Is 1500 watt inverter good? RE: Sinewave inverter anyone have recommendatioms? - uncleal13 - 02-08-2018 (02-07-2018 )Blake Wrote: Fridge, 900 watt small micro, laptop and cpap what size? Is 1500 watt inverter good? As long as it isn’t all on at the same time. I had a 1,000 watt before, it worked fine for a microwave, but would not start a fridge. Anything with a motor needs about 10 times it’s running wattage to start. 1,500 may be enough. I had an 1,800 that worked fine for a fridge. I currently have a 2,500 watt pure sine wave and that’s seems to run everything. Just be sure to use large cables for the power. I use welding cable. RE: Sinewave inverter anyone have recommendatioms? - Rawze - 02-08-2018 I am running this one for about 6 months now... https://amzn.to/2Ln466c Pure sinewave, works good, and handles everything thrown at it so far. It can be bit touchy and will shut down easily if something causes a slight power surge though. I had a power strip that was intermittent causing it to shut down randomly, but once I replaced that strip, it is working good now. RE: Sinewave inverter anyone have recommendatioms? - Chamberpains - 02-08-2020 2 years after your post, How is that inverter working for you Rawze? |
