Injector heip - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Injector heip (/showthread.php?tid=2698) |
Injector heip - IrishKW - 01-31-2018 I pulled injectors #1&2 due to not passing leak test. The top have 4088725 on them the tips have 4088662. According to Quickserve my cpl calls for 4088665. Needing some direction, I know cat injectors have different spray pattern. Not to knowledgeable about Cummins. RE: Injector heip - Rawze - 01-31-2018 What is your engine serial number? RE: Injector heip - IrishKW - 01-31-2018 (01-31-2018 )Rawze Wrote: What is your engine serial number?79227495 cpl 8520 RE: Injector heip - IrishKW - 01-31-2018 Found out I was looking in the wrong place, the metal piece that holds the spring had the part # They are 4088665's Still learning, Thanks for all the help! |
