Injector leak test tool - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Injector leak test tool (/showthread.php?tid=275) |
Injector leak test tool - RTRUCKING48 - 03-30-2016 Where can I get the injector leak test tool? Thanks in advance RE: Injector leak test tool - gatow900 - 03-30-2016 Del-Ter Machine, Inc. 1038 Triplett Blvd. Akron, Ohio 44306 delterprecisionmachine.com Hey makes them RE: Injector leak test tool - Rydemx - 03-30-2016 I made my own with an old line . Works great, If your referring to a common rail isx .... RE: Injector leak test tool - preacherboy24 - 03-30-2016 (03-30-2016 )gatow900 Wrote: Del-Ter Machine, Inc. That is the guy I had make mine. He did a great job. You have to use the flat gaskets with his and not the o rings. RE: Injector leak test tool - RTRUCKING48 - 03-30-2016 Thank you guys i will contact them, great info RE: Injector leak test tool - Rawze - 03-30-2016 I ordered mine from cummins but there are a few guys making them too. RE: Injector leak test tool - RTRUCKING48 - 03-30-2016 Thanks Rawze I will check with them |
