| isx advice - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: isx advice (/showthread.php?tid=2754) |
isx advice - mikestrucks - 02-12-2018 My 03 isx has been a great motor but now has 1.1 million! I have yearly overhead run and its starting to use a gallon of oil about every 10 thousand miles. question is should i go till something major happens or should i be trying to do rods and mains or what options short of a full and costly in frame. Thanks for any guidance! RE: isx advice - Rawze - 02-13-2018 You should have done the rods and mains at 800k to prevent acceleration of wrist pin bushing wear. They are over-due at this point. Many ISX truck owners skip this and then wonder why a piston goes through the block at 1.1 - 1.2 mil miles with no warning due to wrist pin failure. -- you have been warned!. While your at it, you should read through this as well. It is a warning to see how worn out the head is. It starts at the section in the post "Checking worn out valve seats"... http://rawze.com/forums/showthread.php?tid=1106&pid=9466#pid9466 |
