| Bad idle and strange noise after wiring harness repaired - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Bad idle and strange noise after wiring harness repaired (/showthread.php?tid=2760) |
Bad idle and strange noise after wiring harness repaired - alborz - 02-13-2018 First I had code for shortness to high or low voltage source So I removed the engine wire harness and found a few spots with corrosion. I fixed the and put the harness back on engine, meanwhile I took the egr valve off and cleaned it along the pipe and sensors. Now there is stange noise from engine like rocking back and forth If I rev it up a little the noise goes away but returns. Here what I did I unpluged the egr temp sensor then plugged it to another that I had Unplugged the differential sensor and plugged to another differential sensor Same thing for I- Map sensor No change in the noisy engine Engine is ISX 871 Any comments will be greatly appreciated [/b] RE: Bad idle and strange noise after wiring harness repaired - the missing link - 02-14-2018 Almost sounds like egr , try taking the magic plug off .... That about all my knowledge , if you had to find it all , it won't take long ,lol RE: Bad idle and strange noise after wiring harness repaired - smorgan87 - 02-14-2018 Could be egr, could be injectors, could be actuators... Any codes after fixing the harness? |
