Stop engine and check engine light wont clear - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Stop engine and check engine light wont clear (/showthread.php?tid=2766) |
Stop engine and check engine light wont clear - Crod - 02-15-2018 2012 freightliner M2 with cummins isb 6.7 Both check engine light and stop engine light on truck derated to 5miles an hour i put computer to clear codes but lights wont clear on dash board i also did a force regen but state continue to stay inhibited i then unplugged a harness directly under the cab on the drivers side and removed some sensors on the def side of things and the computer did not give any codes but when i unplugged sensor not related to def the computer did give codes any ideas on what can be wrong??? Thanks for the help RE: Stop engine and check engine light wont clear - Rawze - 02-15-2018 Maybe some screen shots of the regen history and other things? Some history, mileage, ect.? Has the DOC/DPF cans been pulled off, inspected, photos of their faces taken, then sent to get baked? - Post some photos of their faces, including the face of the SCR can. RE: Stop engine and check engine light wont clear - Crod - 02-15-2018 130, 000 miles |
