Torque specs high pressure fuel pump - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Torque specs high pressure fuel pump (/showthread.php?tid=2768) |
Torque specs high pressure fuel pump - Magard - 02-15-2018 Torque specs on the 2250 fuel pump. 4 bolt new style pump 10mm 12 point. Looks to be close to 3/8 on the thread. RE: Torque specs high pressure fuel pump - Rawze - 02-15-2018 You should be able to find that on quickserv RE: Torque specs high pressure fuel pump - Magard - 02-15-2018 50 ft. Lbs as per quickserv. Thanks |
