Inline 5 or 6 adaptor kit - Printable Version
+--- Thread: Inline 5 or 6 adaptor kit (/showthread.php?tid=2794)
Inline 5 or 6 adaptor kit - JEM Xpress - 02-23-2018
I am looking to buy an Inline 5 or 6 adaptor kit. My problem is, most of these kits come with an Inline CD to install on your laptop, but it doesn't specify if the insight software is on this CD as well. Is this two of the same or do you have to buy the insight separately? What is the exact phrase or terminology I should search for either via the internet or Ebay? Does anyone know of a site that sells these kits and could possibly post a link? Can a laptop with Windows 10 support the software download? I've seen where they are detailing Windows 7 or 8 only. Any help would be appreciated.
RE: Inline 5 or 6 adaptor kit - Rounded_nut - 02-24-2018
I have 7.6 on windows 10, no problems.
RE: Inline 5 or 6 adaptor kit - JEM Xpress - 02-24-2018
I have been checking out this website for inline 5 and 6. http://www.obdii365.com/. Can someone tell me what they think?
RE: Inline 5 or 6 adaptor kit - Waterloo - 02-25-2018
(02-24-2018 )JEM Xpress Wrote:  I have been checking out this website for inline 5 and 6. http://www.obdii365.com/. Can someone tell me what they think?
Really good price on the Inline unit, looks like everything is there. Outfit selling is out of Hong Kong, but nothing wrong with that, as I think that is where most of us bought ours, I did. Looks like everything is there, including the software.
RE: Inline 5 or 6 adaptor kit - JEM Xpress - 02-25-2018
Cool, I appreciate the feedback. I have no idea what I'm doing when it comes to this kind of stuff. But I am tired of the dealership B.S. Truck went into derate last week. Two engine lights on. Went to Freightliner in Statesville NC. 2 hrs later truck was fixed. Broken wire on back side of tranny somewhere. $310.00 later.
RE: Inline 5 or 6 adaptor kit - MageRoyal - 12-08-2020
those chineese inline adapter CD's come with illegit copy of insite7.6 on em but no keymaker or instructions. Is not an issue tho cause you only the adapter, cables and a laptop to use em on of cousre .
the cd is useless but softwares for 7.6.2 and Clterm etc. to pull & edit your own files with are all on the interwebs in many places 4 free with the keymakers & everything if ya just look 4 it.
