| isx 15 exhaust temperature high - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: isx 15 exhaust temperature high (/showthread.php?tid=2799) |
isx 15 exhaust temperature high - New isxer - 02-23-2018 Just bought a used 2013 Pete 587 on the way home the dash flashed exhaust temperature high. What could have caused this? There is no check engine light. Thnx in advance RE: isx 15 exhaust temperature high - hhow55 - 02-23-2018 [attachment=3622] Did it look like this pic? RE: isx 15 exhaust temperature high - New isxer - 02-24-2018 I think so it flashed up and dissapeared so fast. RE: isx 15 exhaust temperature high - hhow55 - 02-24-2018 Mine comes on all the time, nothing to worry about. It is an indicator of high temp's in the exhaust can. Just don't shut down engine until it cools down. RE: isx 15 exhaust temperature high - Rawze - 02-24-2018 (02-23-2018 )New isxer Wrote: Just bought a used 2013 Pete 587 on the way home the dash flashed exhaust temperature high. What could have caused this? There is no check engine light. Thnx in advance It comes on during passive regen cycles. It is simply telling you not to park under a tree or in tall grass. RE: isx 15 exhaust temperature high - Hammerhead - 02-24-2018 (02-23-2018 )New isxer Wrote: Just bought a used 2013 Pete 587 on the way home the dash flashed exhaust temperature high. What could have caused this? There is no check engine light. Thnx in advance (02-24-2018 )Rawze Wrote: It comes on during passive regen cycles. It is simply telling you not to park under a tree or in tall grass. ...unless your insurance policy is paid up, your truck has been giving you lots of frustrating issues so you're fed up and you're looking for a "way out"... RE: isx 15 exhaust temperature high - New isxer - 02-24-2018 |
