| Two speed fan clutch - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Two speed fan clutch (/showthread.php?tid=2802) |
Two speed fan clutch - Magard - 02-24-2018 Anyone have experience running a two speed fan clutch. Putting a new fan clutch on and thinking of going this way. I don’t have a manual switch. This seems like a good alternative for idling and not cycling the fan on and off as much running the air conditioning. RE: Two speed fan clutch - redbeard - 02-24-2018 At first I questioned the idea, now I embrace it on my truck. Dust free cruising in parking lots and most job sites, even with the ac on. The principal and engineering behind them is pretty smart. I have know idea of the replacement cost. RE: Two speed fan clutch - Rawze - 02-24-2018 Here is another thread where this was discussed a while back. Maybe it is helpful too. http://rawze.com/forums/showthread.php?tid=1968&pid=16877#pid16877 RE: Two speed fan clutch - Magard - 02-24-2018 I see Uniliever isn’t a fan of them. That’s good enough for me. Thanks. RE: Two speed fan clutch - Signature620 - 02-24-2018 Don't use a 2 speed if you spend time in dusty areas or dont have a bug screen. Your radiator and CAC will be clogged all the time. RE: Two speed fan clutch - redbeard - 02-24-2018 I’m not getting this. My Fan just spins just enough to not raise dust and keep the a/c condenser from spiking pressure and kick the fan in on direct and cause a dust storm. Being a California truck cold weather is pretty much a none issue. With just an air activated clutch, using manual over ride before arriving to avoid the dust storm is a thing of the past. Maybe I’m just lucky RE: Two speed fan clutch - Chamberpains - 02-25-2018 Quote:Posted by redbeard - Today Quote:Being a California truck cold weather is pretty much a none issue. Hahaha, I think you didn't get it until you posted the second statement. It's a cold weather problem. Almost all OTR guys would deal with this being a keeping warm issue at some point. |
