In trouble .. truck won't regen - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: In trouble .. truck won't regen (/showthread.php?tid=2906) |
In trouble .. truck won't regen - JHNDZ - 03-23-2018 I got insite running and I was observing the truck history .. I went on the features and parameters..and I decided to open her up a bit .. changed the idle to 10 min. .. let the rpm go to 1800 .. instead of 1600 .. ... gave her 70 mph on cruise c only .. Saved the setting and success .. ran like a champ but !! After about 30 miles the regen light comes on .and it won't regen .. ?? .. Did a forced regen with insite but temps only get to 800 .. cuz the injector is not turning on .. I have a lot of codes for egr low voltage egr delta p.. 411 derate .. showing moderate level soot .. ??.. did I do this by. Changing the ecm?? .. can I do a default setting ?? Any advice RE: In trouble .. truck won't regen - hhow55 - 03-23-2018 Right click on the active code's, follow the trouble shooting tree. RE: In trouble .. truck won't regen - JHNDZ - 03-23-2018 These are my codes now .. |
