Ultrashift 2012 cascadia clutch groaning - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Freightliner related help (/forumdisplay.php?fid=75) +--- Thread: Ultrashift 2012 cascadia clutch groaning (/showthread.php?tid=2926) |
Ultrashift 2012 cascadia clutch groaning - Sergiu - 03-26-2018 Ultrashift 2012 cascadia clutch groaning when starting from place, especially when heavy. Have replaced the clutch but no changes. What can it be ? RE: Ultrashift 2012 cascadia clutch groaning - the missing link - 03-26-2018 Motor mounts ? Put your hand on the stick , if it moves when you lift its the mounts . If they did not check them when they did the clutch they need their ass kicked ... Mine are not in great shape , I am going do a tear down and do the clutch , mounts , rear structure . I just have to find the right time . I would also check all the bell housing bolts ... Just seen its a ultra shift . RE: Ultrashift 2012 cascadia clutch groaning - redtick - 03-26-2018 Pilot bearing, release bearing and input bearing are in that area. Worn input shaft could cause the clutch disc to bind. Loose rivets on the clutch plate can chatter. Just a laundry list of things that can happen. |
