def tank filter - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: def tank filter (/showthread.php?tid=2952) |
def tank filter - lonestar16 - 04-02-2018 hello i change out my def tank filter this pat wkn in now i cant hear the pump when i turn the truck off ..my truck is a 2016 lonestar with a cummins isx cm2350 RE: def tank filter - rrod - 04-03-2018 Sometimes it doesn’t do the purge cycle if the truck hasn’t run long enough to start the process of priming the lines. RE: def tank filter - lonestar16 - 04-03-2018 seem to be working now so it seam like what u said about it needing to purge was right |
