| OODO-New Delta-P and Map Sensors - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: OODO-New Delta-P and Map Sensors (/showthread.php?tid=2992) |
OODO-New Delta-P and Map Sensors - bossboy2 - 04-12-2018 Finally got around to installing the new DP-sensor and Map sensor today. The DP sensor comes in a kit ($98) which included all necessary hardware and a new pigtail. My truck already came issued with the upgrade but I went ahead and replaced the pigtail as I broke the retaining clip on the old one. Too brittle. Made sure to clean the ports while it was off. BTW, if you do install a new Delta-P, you need to get the ECM reset by someone who has the software. There is a possibility you can throw a code because the ECM uses a "learned" value for comparison purposes when you shut it down. Then if you have a new sensor it'll be looking for that value and if it's not correct, it'll throw a code. We'll see if it helps starting tomorrow. All last week the best mpg I was able to achieve was 8.1. We'll see. RE: OODO-New Delta-P and Map Sensors - Rawze - 04-12-2018 (04-12-2018 )bossboy2 Wrote: ..http://rawze.com/forums/showthread.php?tid=1485&pid=25590#pid25590 |
