Cascadia DD13 Oil Bypass Question - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Freightliner related help (/forumdisplay.php?fid=75) +--- Thread: Cascadia DD13 Oil Bypass Question (/showthread.php?tid=3008) |
Cascadia DD13 Oil Bypass Question - bossboy2 - 04-18-2018 Has anyone installed a bypass system on the Cascadia DD series engine? If so, where did you mount the unit? Did you purchase a "bypass kit"? If not a kit, what type of supply/return lines did you use? Where did you make the connections for supply and return? And lastly, do you think it's even necessary after 690k miles? RE: Cascadia DD13 Oil Bypass Question - dhirocz - 04-19-2018 Any reduction of soot in the oil is good. It will not hurt to run a bypass filter. As far as where to mount it, you need to find a space that works...safe from road debris, rubbing on the filter, and somewhere that clears the hood and other components. I used the amsoil kit...no complaints. Buy a couple extra filters...keep one under your bunk just in case, shops won't carry them! As far as hoses and fittings, I would decide where you plan on connecting the inlet and outlet, and stop by a hydraulic shop and pick up the correct fittings and hose. You can use reusable JIC, like I did so I can change the hose if needed, or have the shop custom make you a set. As far as specifics on DD engines, I'm clueless there. |
