| Need help Volvo owners. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Need help Volvo owners. (/showthread.php?tid=3011) |
Need help Volvo owners. - snailexpress - 04-19-2018 I have my Volvo brakes acting up and ABS module is under suspicious. No any codes on dash. I have Bendix software to diagnose the ABS module but it wont work as it says in Bendix manual. Software properly identify ABS module which is EC-60 but when I try to connect to the module and read stored codes it says FAIL TO COMMUNICATE. I ask you, if you have Inline adapter, to download and install Bendix software and try to read your ABS module to check is it working. Sftware is here http://www.bendix.com/en/servicessupport/abssoftware/diagnostics_subpages/acom65.jsp on very bottom. Any question how to install or run please PM me and I will call you. Thank you. RE: Need help Volvo owners. - Rawze - 04-19-2018 I use jpro for mine. RE: Need help Volvo owners. - Hammerhead - 04-20-2018 I have the same ABS module as you do snailexpress, as well as the same software you posted. I get the same message when I try to connect using my Inline 5, even though Bendix says it's compatible... Apparently not! RE: Need help Volvo owners. - snailexpress - 04-20-2018 (04-20-2018 )Hammerhead Wrote: I have the same ABS module as you do snailexpress, as well as the same software you posted.Thank you my friend. This is was my suspicious. The older version Bendix was working good. |
