Any way to produce boost at idle? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Any way to produce boost at idle? (/showthread.php?tid=3015) |
Any way to produce boost at idle? - Brock - 04-20-2018 On my 871 I am wondering if there is a way to get this thing to produce boost at a idle? Like a boost leak file per say where instead of hooking up a contraption to check for boost leaks, I could quickly swap in my test program that produces 10psi or so at idle and just quickly run soap and water over everything..... Closing the min and max table doesn't do Jack. My 60 series with its vnt turbo produced boost at idle so it was real nice for checking for leaks. RE: Any way to produce boost at idle? - Nilao - 04-20-2018 Should be able to tell it through CTerm to close to 70 or 80% RE: Any way to produce boost at idle? - Brock - 04-20-2018 I went 60 and it did nothing. RE: Any way to produce boost at idle? - Unilevers - 04-20-2018 set the cruise at 1000 and close it to 80%, it will make boost. uni |
