| Fuel gauge problem - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Fuel gauge problem (/showthread.php?tid=302) |
Fuel gauge problem - Crafter - 04-08-2016 So my fuel gauge has been acting up lately. The other day, during a forced regen the gauge went from half full to empty, ding ding ding sound.. I freaked out, used my measuring stick to make sure I had fuel. Tanks were half full. Now it's working but it goes on and off from time to time. Any suggestions? I also think it's off by 1/8. It always showing more than it actually is. What should I change or can I clean something? RE: Fuel gauge problem - mkmac - 04-08-2016 (04-08-2016 )Crafter Wrote: So my fuel gauge has been acting up lately. First thing I would do is clean the connection at the sending unit and the plug make sure you have a good connection..... |
