Owners manual - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Other truck related Help... (/forumdisplay.php?fid=71) +--- Thread: Owners manual (/showthread.php?tid=3048) |
Owners manual - Friedline1805 - 05-01-2018 Hi team first time on forum, not sure if this is the correct category. I have a 2012 volvo and a 2011 isx cm2250. Would like to start doing my own greasing on the truck. Having a hard time finding material on how to find all the grease points if anybody could point me in the right direction!! RE: Owners manual - tree98 - 05-01-2018 probably won't find any grease zerks on your motor. As for your Volvo chassis, contact a dealer about an owners manual, but you can start by getting under your front end, look at all your steering components, anywhere there is a connection there will be a grease fitting. Don't grease them until the rubber boots explode!! just a few pumps and you should see the boot inflate a little, STOP there!! You'll have a grease fitting on your throw out bearing if you have a manual trans. that one could be tricky to find if you've never greased a truck before. each U-joint will have one, don't grease those to death either. each S-cam tube and slack adjuster will have a fitting. You can definitely overgrease things and cause damage so take it easy. RE: Owners manual - Volvo8873 - 05-01-2018 Volvo are basically the same as any other truck. Like tree98 said above... Steering suspension slack adjusters/brakes throw out bearing on transmission slider on fifth wheel? through some of that grease on your fifth wheel plate also. I don’t think there is one manual fits all when it comes down to it. Let us know if you do come across something. RE: Owners manual - snailexpress - 05-01-2018 Good question because Volvo is special animal. First special things U-joints are not greaseble. Same about drive shaft splins. Do not use moly grease on slack adjusters. When greasing S-cam put piece of cardboard inside the drum under s-cam to prevent grease on brake. King pins must be greased top and bottom. All points from driver front side - 1Front spring pin left and right 2 Drag link front 3 King pin (top and bottom) left and right 4Steering shaft U-joint 5Drag link rear 6Toe rod left and right 7Rear sprig pin left and right 8 Rear spring hanger pin left and right 9Throw bearing 10 Slack adjusters 11 S-cam brackets 12 Fifth wheel Some information about Volvo you can find here https://volvotrucks.vg-emedia.com/ |
