| Need some help identifying part #'s - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Need some help identifying part #'s (/showthread.php?tid=3057) |
Need some help identifying part #'s - Volvo8873 - 05-02-2018 I have the 2250 time bomb fuel pump on my engine yet and have a rebuilt 2 cylinder ready to go on. Problem is I don't know what the part numbers are for the fuel lines? I also read that I need new brackets? Cummins quick serve basically just shows me the 3 cylinder pump and the part numbers for the tappets and plungers are the updated ones. So I went to Cummins and they brought up everything and were going to sell me the 3 cylinder hardware yet. I said this is the new updated 2 cylinder pump so I asked if I can get those and he got pissy and said that this is it. I basically said alright and walked out of there calm and collectively. Can any of you guys help me out? I have the part # for the one hose but I am just shooting blanks at this moment. Thanks RE: Need some help identifying part #'s - Starlight - 05-02-2018 Click on the tsb that pops up beside the part number on the part supersession screen. It'll tell you to update to the 2 cylinder design as well as all the needed parts / fuel lines to do the retrofit. RE: Need some help identifying part #'s - Volvo8873 - 05-04-2018 (05-02-2018 )Starlight Wrote: Click on the tsb that pops up beside the part number on the part supersession screen. It'll tell you to update to the 2 cylinder design as well as all the needed parts / fuel lines to do the retrofit. Thank you! Apparently I just needed to do some more digging. |
