| ecm programing - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: ecm programing (/showthread.php?tid=3100) |
ecm programing - tdawg - 05-13-2018 I have an extra ecm 2005 435st out of a international. is there any reason it would not work on my 2005 Volvo? I'm swapping out the motor and would like to put a good program in the extra ecm. rite now it wont rev up over 1400 rpms. RE: ecm programing - marek4792 - 05-13-2018 Volvo has J1939/J1708 multiplexing but it shouldn't be too hard to set up RE: ecm programing - tdawg - 05-14-2018 (05-13-2018 )marek4792 Wrote: Volvo has J1939/J1708 multiplexing but it shouldn't be too hard to set upI don't know anything about programing so does that mean cummins could program the one out of the international to work on my Volvo? RE: ecm programing - Mr Hagg - 05-14-2018 if you have insite do work order and convert to image to save info. As far as the 1400 insite can change that easy to with out programming ....You will need to know what engine CPL you are putting in that way you know which cal you need . .GEt with UNILEVERS on here he is the best with these 870 engines. |
